EniacLoona In fact, the performance of the Exynos 1480 is comparable to that of a Snapdragon 865, Being inferior to it in every way, there is no comparison with the sd888. Although, there is no source that says it is comparable to the sd888. Possibly the most apt comparison for the Exynos 1480 is the Exynos 990.
In fact, the Exynos 1580 leaks only say that it will be more powerful than the SD888. However, the first benchmarks have shown a performance similar to the SD865+, without reaching the 870.
On the other hand, the Exynos 1380 is even inferior to the 855 in every way. In cores, GPU, etc., there is no source that compares it to the 7gen1. In fact, it is known to be an Exynos with poor resource management.
Honestly, the exynos you mentioned are not equivalent to the snapdragons you listed. Maybe that’s why you find them disappointing, because you have a higher vision of what they actually are.
It is important to remember that not everything is based on the numbers that the benchmarks can give. There are also more general specifications of the processor to consider. In this case, the limitation they have as a “mid-range” is noticeable when you compare their performance cores with those of the same high-end Exynos o snapdragon.
