Dreame X40 Pro Ultra – Beta Tester Review
As a beta tester for the Dreame X40 Pro Ultra, I’ve had the opportunity to use this robot extensively from its early development stages. It’s an impressive device packed with innovative features and cutting-edge technology. Here’s my detailed review:
Key Features & Specifications
🔹 Suction Power: An incredible 13,000 Pa of suction ensures thorough cleaning.
🔹 Dual Cleaning Systems: Features dual rotating mops and double rubber rollers for enhanced cleaning efficiency.
🔹 Hot Mop Washing: Washes mops at up to 75°C with adjustable water temperature (4 stages).
🔹 Dirt Detection: Automatically adjusts cleaning intensity based on dirt levels.
🔹 Smart Features: Intelligent re-mopping, re-washing, host language control, and pet-friendly modes.
🔹 Obstacle Avoidance: Combines LIDAR, dual-line lasers, AI vision, and LED night vision to avoid 140+ ground obstacles dynamically.
🔹 Edge Cleaning: Features a side brush and mechanical arm for precise edge cleaning.
🔹 Triple Lifting System: Lifts the mop, main brush, and side brush to avoid wet carpets and secondary pollution.
🔹 Dust & Water Tanks: 3.2L dust bag and an 80ml water tank.
🔹 Self-Cleaning & Deodorization: Equipped with mop warm drying and base station self-cleaning.
🔹 Optional Add-ons: Automatic water supply, drainage, and cleaning solution dispenser.
Unboxing Experience
One of the standout aspects of Dreame products is the high-class unboxing experience. The X40 Pro Ultra continues this tradition, offering sleek and well-organized packaging that ensures every component is securely placed and easily accessible. The premium presentation reflects Dreame’s commitment to quality and innovation, making the initial experience feel luxurious and exciting.
Pros
Outstanding Mopping Performance: The dual rotating mops and hot water cleaning deliver spotless results, especially on hard surfaces.
Innovative LIDAR System: Adjustable LIDAR allows cleaning under low-lying furniture, a unique feature.
Quiet Operation: Industry-leading noise reduction ensures minimal disturbance, even during vacuuming.
Comprehensive Cleaning: Handles dirt, dust, and debris efficiently, with intelligent adjustments for stubborn areas.
High-Class Presentation: From unboxing to setup, Dreame ensures a premium user experience.
Cons
Not Ideal for Pet Owners: Long pet hair wraps around the dual rollers, requiring frequent maintenance, making it less suitable for households with pets.
Handling Long Hair: Struggles with long hair, which often clogs the rollers and requires regular cleaning.
Lack of Updates: Since the beta testing phase ended, the robot hasn’t received any firmware updates, limiting its potential improvement.
Regional Availability: Currently launched only in Singapore, with no clear timeline for global availability.
Voice & System Control: Works only in English, which may limit usability for non-English speakers.
🟢 Overall Impression
The Dreame X40 Pro Ultra is a high-performance robot vacuum and mop with unparalleled cleaning capabilities on hard surfaces. The luxurious unboxing and presentation further enhance the premium feel of the product.
However, its struggles with long pet hair and the absence of post-launch updates are notable drawbacks. For pet owners or households with long hair, this robot may not be the best choice. With consistent updates, multilingual support, and expanded global availability, the X40 Pro Ultra could become a leading contender in the smart cleaning industry.
