Hi,
I log in in the Amazon Prime Video app (installed by Aptoide), but when I clic play on an episode, It shows me an HDMI connection errore.
Any tip?
Thanks
    separate_paco Try to do a reset on the Boxe and check again if shows problem.
    Insert an eject sim tool in the hole and you will reset the boxe.
    If not works try with an amazon stick 😉👍
      5 days later
      Helen
      Here you are, thank you very much
      (Sorry I haven’t been able to upload .avi .mp4 .wmv ore .zip file)
        7 days later
        separate_paco I know that it is not the perfect solution, but you use the amazon stick in the hdmi port of the heyup boxe and it will work
        6 days later
